Considering Nascar Boom Tube
But the real question is what exhaust to go with? Ive done tons of research and I wanted the Loudmouth System but then decided on True Duals... I have done a bit of reading on the Boom Tube and it sounds mean as hell and looks awesome to. But the problem is I live in a small town of around 10,000 in SD and im almost certain that no one in my area will be able to help with the install which sounds pretty tuff... Im almost certain I will be going with the boom tube and would like to do a dual setup... I would just like to try and gather any input I can before ordering the exhaust. Basically I would like to know exactly what the board thinks about headers, y/x pipe?, tips and all that to go with the tubes and any recommendations on who could perform the install and do a good job... im not really concerned with the heat issue I just figure I will use tape but I dont know how well the exhaust will go with the charger... money isnt an issue at the moment I have been saving up for a couple years now and have plenty to spend I figured if I was going to build my dream machine I wanted to have the funds to afford the best.
Also would you recommend a weld in or bolt in roll cage with the power im going to have? I would like to just be able to bolt in but im not sure if that will hold up by the time im done modifying the car. Any Cam sugguestions would be great to.
Any Help Would Be Greatly Appreciated Thanks!!!
He has a Boomtube setup.. That thing sounds sick.. I'm sure that he can answer all of your questions.
Thanks
Thanks
I thought that I saw something similar to an x-junction. I maybe wrong..
