burnt wiring on header question....
What wires were effected and should I be concerned?? Also, the small harness that holds the O2 sensor wires is only about a half inch from touching the header....is this too close too??
You can also add some wire clips to secure the wires so that it doesn't happen again..
I had it happen with the wire that runs to the AC Compressor... Needless to say, I had to solder in a replacement section.
Good luck..
