header installed yesterday!
Old Aug 31, 2004 | 12:28 AM
blkZ28spt's Avatar
Originally Posted by HumpinSS
I have QTP HV merge headers and it made the car run EXTREMELY rich with them hooked up. Trims maxed at +25 and the car wouldnt pull for **** over 2k rpm because of the rich condition.
But there will always be naysayer and people that have done this and that with no ill effects so I guess my understanding of the PCM and the effects fresh air on the o2 sensors was all a bad dream.
Carry on
I think it's a safe assumption that people are overlooking the differences between different brands of headers and how far away they locate the O2's from the outside air. How far from the O2's is it to the atmosphere with your QTP HV merger collectors???
Old Aug 31, 2004 | 08:31 AM
HumpinSS's Avatar
Right where the pipe neck down into the collector. above the "w"
Old Aug 31, 2004 | 08:36 AM
buschman's Avatar
I believe HumpinSS is dead on with his assesment. Some people will be able to get away with open headers, but this is most certainly your problem. As for why your car won't start, you've probably fouled your plugs. Pull them out and I bet they are as black as night and filled with soot. If they are expensive unit, you can try cleaning them up and removing some of the carbon. Otherwise, get a new set and I bet it will fire up again. Just don't expect the new plugs to last much longer under the same conditions.
Good luck,
Mike
Old Aug 31, 2004 | 08:38 AM
hourang's Avatar
is it cranking over?
Old Aug 31, 2004 | 11:14 AM
Ta's02Ws6's Avatar
no its not starting, it acts like the battery is dead but it is not i tried jumping it and also my lights are bright as they were before. it sounds like it is just spinning the starter well more or a weird noise thought im gonna try to fix it tonight if anabody has any ideas what it could be let me know thanks trevor!
Old Aug 31, 2004 | 02:56 PM
blkZ28spt's Avatar
When he asked if it's cranking over, it can crank over without firing/starting. Can you tell if the crank is rotating when you turn the key? I am fairly unfamilier with SLP's......did you have to move/remove the starter to get them in? Plug change wouldn't be a bad idea.
I am just now ordering new plugs after I drove for weeks open header last year. It ran okay though.
Old Sep 1, 2004 | 12:37 AM
Ta's02Ws6's Avatar
no i just got done taking out my starter and the damn starter ingages but does not spinn. i have a question about my warrenty, I took out my starter and it is screwed can i just take it to my local dealer with my title and get a new one or how hoes it work because i just took it to the dealership about 2 months ago.
