How to flush coolant properly.
1. There's the little tube that connects to the radiator right below the cap and the reservior tube, take that off and let it drain into a bottle or bowl. Plug the radiator end. Also either put a kink in the reservior tube or remove and plug.
2. Fill radiator with 50/50 mix and blow into radiator (careful, don't swollow any coolant) to pressurize system.
3. Keep refilling and pressurizing the radiator/system until you get a steady stream of coolant running out of the above mentioned tube that was directed into a bottle. This would eliminate the air pockets in the block and heads.
4. put the lines back on (making sure you don't get much air in the tubes) and top up the radiator.
As for the bottle, keeping it filled to the level on the dipstick is sufficient. Don't overfill, makes a mess like yours. lol
Hope this info helps. Anyone else, feel free to chime in with comments!
