To Much Popping....HELP!
Old Sep 6, 2004 | 06:22 PM
RGV_Z28's Avatar
Default To Much Popping....HELP!
My exhaust is popping way too much when i punch it. Evened popped at idle once. I might have a loose plug or wire. Could this be the reason. Im running Pacesetter Lt's with true duals and dynomax 12 inch bullets. Any suggestions on the problem or even better, the answer. thanks guys.
-john
Old Sep 6, 2004 | 09:07 PM
Uno99's Avatar
Check your plugs and wires first. Could be a cracked plug or just loose. Good luck.
