Cold start problem, could use some help.
Old Sep 8, 2004 | 11:07 AM
v8maro's Avatar
Default Cold start problem, could use some help.
Ok, this only happens when the car is first started and when cold. I'll start the car, the cam has a little surge to it because it's large, then I take off to go to work. Well, sometimes, not all, when I take off, the car falls flat on it's face, push the gas and it feels like a huge miss-fire, don't know how to explain it better, put the gas down and it studders, shakes, surges, clutch chatter, u name it. If i let off the gas and then rev up higher and pull the clutch out slow, it will barely surge, then get going. After a few minutes of driving, the car starts to behave like normal.
I want to check a few things and I want to see what you guys have to say:
Plugs, are they fouled? Oil covered? - will check.
How can I check to see if it's my clutch that is bad?
Could this be fuel pump/filter related?
Any other ideas you guys think I am missing?
Car doesn't seem down on power so I dont think it's a spring or pushrods.
thanks
-Steve
Old Sep 8, 2004 | 06:18 PM
v8maro's Avatar
anyone?
Old Sep 8, 2004 | 06:34 PM
Scalpel's Avatar
Oxygen sensor.
Old Sep 8, 2004 | 06:41 PM
v8maro's Avatar
Hrm, didn't think of that one. What puzzles me is that no codes are going off, that makes me think the clutch could be the problem
Old Sep 8, 2004 | 06:47 PM
Scalpel's Avatar
It's not the clutch.
What you described is what I have seen on 3 different LS1 cars, they didn't throw codes for the O2, either.
Old Sep 8, 2004 | 06:50 PM
Scalpel's Avatar
If you want to test the clutch. Get on the highway, get to 55-60MPH in 6th gear and punch it. If the RPMs don't shoot up then your clutch is most likely fine.
Old Sep 8, 2004 | 07:36 PM
v8maro's Avatar
Ok, how can I test my o2's then? It only happens for like 10mins then goes away.
