car having trouble starting after LS6 install HELP PLEASE
hello everyone, I installed a ls6 intake and plugs this past weekend and upon firing the car, it is taking like 7 tries to get it going, same thing as when there is no spark, what does everyone think, I just got the idea that maybe I cut the wire that is connected to the driver side head and the ground is not making contact.....I will check that tomorrow.
anyways I am out of ideas, lets see how many more we can generate to tackle this problem, I thank you in advance.
P.S
I made sure all the plugs and everything was connected right. nothing is disconnected.....
thanks
David
P.S
thanks
David
fuel injector plugs are good, it does turn, but there is no spark to set the combustion for what i can tell, but the weird thing is that sometimes it does start up, but i have to keep on trying. I checked the ground on the back of the head and it seem to be connected right, any more ideas before I take everything apart again?
Also I did not lubed the O-rings on the injectors when I installed them in the new manifold, you think that this is causing a air leak and causing this problem>
thanks again
thanks again
yes I did unhook the coil packs but they were connected, I think I found the problem to be a short on the ground behind the DS head, I was trying to get it to run and shaking that ground and it would start up everytime, so i think I have to reatach the ground becuase it has a shor from tugging on the wire I guess, but the car is running fine now
thanks
thanks
thanks
thanks
