TB Opening Too Much
Old Sep 14, 2004 | 01:28 PM
BoneSS's Avatar
Default TB Opening Too Much
Will my ported tb opening too much at wot hurt performance? I know the voltage changes--I threw a po123 code, and know how to fix it, but I want to do it right and accurate, thus use HPTuner when I order it here in a little bit. I didn't know if it would hurt anything in the short term? Also, does this hurt performance alot at wot? Thanks.
Old Sep 14, 2004 | 03:28 PM
chpmnsws6's Avatar
time to epoxy some material back on...
Old Sep 14, 2004 | 03:38 PM
BoneSS's Avatar
Or bend the shaft. Haven't decided which. I installed the ls6 intake/ported tb at the same time, after 500 miles, decided to try her out. Would this have hurt the results?
Old Sep 14, 2004 | 06:52 PM
Another_User's Avatar
Neither. Buy a set screw, drill and tap where you over carved it and put the set screw in. Adjust, repeat until you reach the right voltage.
Old Sep 14, 2004 | 07:07 PM
Scalpel's Avatar
What should the TPS voltage be?
Old Sep 14, 2004 | 07:40 PM
The DTC sets at 4.65. No more than 4.6 should be fine.
