I bought ENTIRE pcv valve system....
Old Sep 16, 2004 | 12:26 AM
psykoTA's Avatar
Default I bought ENTIRE pcv valve system....
Went to dealer: Asked for PCV valve: said they couldn't seperate valve from the rest of the 2 feet of PCV piping: So i bought the whole thing $70, thought sure why not, replace it all, but once I saw where the friggin' hoses snake around to, It doesn't look worth all the trouble....Just wonderiing if anyone else had replaced everything from the PCV valve back?? Can't decide what to do, replace just the valve, or replace it ALL, valve and the PCV hoses (pre-formed plastic tubes)....Car only has 64k on it, I am thinkin it might be able to wait......Help please......
Old Sep 16, 2004 | 12:51 AM
jrp's Avatar
jrp
SN95 Director
since you have the whole PCV setup you might as well use it. replacement should take you more the 30 minutes, its very easy.
and you could of bought the PCV seperate somewhere else, i got mine from Paceparts for like 10 bucks or something, im sure SDPC sells it seperate as well.
Old Sep 16, 2004 | 01:30 AM
pimpmaro's Avatar
Hell, I'd take it back and go to Napa... I got a PCV valve for around $10 as well... maybe even less. Took all of 15 seconds to swap it... maybe 30 if you consider opening and closing the hood.
