Header Heat
Old Sep 19, 2004 | 11:01 AM
Bill's 02 Z-28 SS's Avatar
Default Header Heat
Hi Folks
Yesterday, I had the car idling and playing around with the tuning. I measured the outside temperature of the SLP LT headers (#1 & #2). Cylinder #1 measured 571 degrees F and # measured 470 F. I know it is outside temperate of the headers but I would have expected them to be closer. Any thoughts on the subject?
Thanks
Bill
PS: no codes and the car runs good
Old Sep 19, 2004 | 01:16 PM
Gloveperson's Avatar
Did you mesure them exactly the same difference from the exhaust port of the cylinder?
-Todd
Old Sep 19, 2004 | 02:20 PM
Hi Todd
yes - went back & forth a couple of times - same results.
Bill
Old Sep 19, 2004 | 07:05 PM
Cstick's Avatar
I have seen that alot. Not necessarily on LS1s but I monitor the temp of the headers on my dragster and there are certain cylinders that run 100 hotter. If you are worried about it the best thing possible would be to do an injector balance test if you know someone or shop with the tester to make sure that cylider is not lean. But what you said does not suprise me.
Old Sep 20, 2004 | 11:55 AM
Thanks - the injectors are new and balanced (that is what I paid for). I will not worry about it any more - thanks for the infor.
Bill
