Info on ls6 intake swap please?
Old Sep 23, 2004 | 07:59 PM
LS1FIRE's Avatar
Default Info on ls6 intake swap please?
What is everything i need to know when doing a ls6 intake swap? I know that i will have to remove the egr and air. Will it throw a code? Is there any tuning involved? Should i purchase the intake with the injectors and fuel rails? Some info on this will be greatly apreciated.
Old Sep 23, 2004 | 08:45 PM
code4's Avatar
Maybe this will help?
http://ls1howto.com/index.php?articl...932f72c3842e70
Old Sep 23, 2004 | 09:02 PM
cyphur's Avatar
um no need to get fuel rails and injectors unless yours are busted.....and you don't HAVE to remove the air. just the EGR. read the article....says everything you need to know. if you have any other questions....SEARCH!!!
Old Sep 23, 2004 | 09:27 PM
LS1FIRE's Avatar
Thank you for your time. I will defeinatly use the search!!!.Just trying to gain much as information as possible.
When doing a ls6 intake swap is it still good to use the stock throttle body?
Old Sep 23, 2004 | 11:18 PM
'Trust''s Avatar
Stock TB will be just fine
