Cleaning oil gunk from intake manifold
Old Oct 1, 2004 | 12:35 AM
robertbartsch's Avatar
Default Cleaning oil gunk from intake manifold
My plastic manifold is caked with a thick tar-like oil substance and it is currently off the engine while I am replacing the cam sensor and oil pressure switch.
So I was thinking of:
1. Spraying top engine cleaner into the manifold ports and cleaning them out with paper towels or rags
2. Putting the whole manifold into a bath tub filled with hot soapie water
3. Spraying the open ports with break cleaner and getting as much gunk out as possible with paper towels or rags.
Question:
So which is the best method; or should I just leave the oil gunk in place and not worry?
Old Oct 1, 2004 | 10:42 AM
Perhaps I should just swap back to the LS1 manifold which is not caked with oil-like sludge?
Old Oct 1, 2004 | 11:09 AM
Krab's Avatar
When I got my LS6 intake, I bought a bottle of concentrated dawn dish washing soap and dumped half the bottle into a tub of hot water. I just submerged the entire intake in there for about 24 hours, and it came out pretty clean. Just be sure to let it completely dry before re-installing it. Wouldn't want to start the engine with some water in the intake.
Old Oct 1, 2004 | 12:07 PM
Samba242's Avatar
When I switched to the LS6 intake, I wanted to clean the old LS1 intake before storing it. There was quite a bit of oil build -up. I did like Krab did with the dishwashing soap ( I think it was Palmolive heavy duty or something) and soaked it overnight. Then I did the inside with one of those brushes used to clean tall glasses. ( like a 10" wire handle with a round brush at the end) Worked well and the manifold is like new.
Old Oct 1, 2004 | 12:31 PM
Z28Venom's Avatar
I used GM Topend Cleaner... Intake was as clean as a whistle afterwards.
Old Oct 1, 2004 | 03:12 PM
OK Great.
On the back of the intake manifold there is an electronic sensor that I believe is connected to the brake vacuume line. I assume it is a vaccume sensor.
Questions: Will the soapie water hurt the vacuume sensor. I assume the GM Top Cleaner is OK on this point... Did anyone deal with the oil-gunk caked on the intake ports of the heads? How?
Thanks....
Old Oct 2, 2004 | 11:45 AM
so what about the sensor?
Old Oct 2, 2004 | 07:06 PM
DrkPhx's Avatar
That is the MAP sensor. Be careful with it. If you're cleaning the intake off the car, remove the sensor first.
BTW - I sprayed engine cleaner in mine, then shot high pressure water (hose nozzle) in there to clean it. Worked great.
Old Oct 2, 2004 | 08:46 PM
DaleMX's Avatar
Put the intake in a plastic garbage can, not the tub.
Old Oct 3, 2004 | 12:53 PM
Is there a trick to removing the MAP sensor from the back of the plastic intake? Is it just pressed in there and held with an o-ring?
Old Oct 3, 2004 | 01:42 PM
Scalpel's Avatar
It should just pull out.
Old Oct 3, 2004 | 07:41 PM
OK, thanks
