A/C Condensor went out, $1200 to fix?
Old Oct 9, 2004 | 08:14 PM
JEspinoza's Avatar
Default A/C Condensor went out, $1200 to fix?
I made a road trip home from college station (4 hour drive) and when I got back, the next day my air condition was hot. It would not blow cold air and so my father and I thought it needed some freeon maybe. We took it to Firestone for them to recharge the Freeon in the A/C and they told us that it is not that. They said that the whole A/C Compressor is shot. They said it would be $1200 to replace because of uninstall and install. I have to leave back to school tomorrow but am going to leave my car here and take my father's truck.
But basically, is this right? I have no real knowledge of air conditioning systems and how they work. However, when you flip the air on you can hear the compressor turn on so I do not know. Can anyone give me any sort of advice or lead me into any direction on this topic? I greatly appreciate your help.
Thanks, Jason.
Old Oct 9, 2004 | 08:35 PM
Z28Venom's Avatar
Thanks, Jason.
You're getting bent over if you pay $1200 to replace a compressor. You can pick up one used for $100 - $150. Install should take no more than an 1hr. Then all you have to do is pay to have your system recharged.
Trust me. Pick up a used compressor or even a new one $275, and do the install yourself.
Old Oct 9, 2004 | 08:43 PM
Another_User's Avatar
AC compressor pricing from gmpartsdirect:
CORE CHARGE: $0.00
GM LIST: $723.30
OUR PRICE: $361.65
Even IF you payed list price, which I sincerely doubt you would, you are still getting raked over the coals.
I also doubt you would get a GM one from them either. Advance Auto has one that will fit you application (remanufactured) for $248.88 with a $10 core charge. Autozone has one for $249.99 with a $30 core. Firestone sucks. Never get work done at the first place you go to unless you know the shop, or you know that you are getting a good deal.
Here is a picture to describe your situation:
You ---> <--- Firestone ........Any questions?
Old Oct 9, 2004 | 09:12 PM
Classic's Avatar
Yep, just like they said -- takes all of 30 minutes to swap the compressor out. Then you can recharge it yourself or pay to have it recharged.
Old Oct 10, 2004 | 05:56 AM
14u2nv's Avatar
Keep in mind they are most likely using a flat rate repair quote. Before I had my H/C installed I called a local Chevy dealer service dept. and they wanted 18 hours to install head gaskets
Old Oct 10, 2004 | 06:05 AM
2MuchRiceMakesMeSick's Avatar
Your not really considering paying 1200 bucks are you? If it was me, I would just roll the windows down (and I do). If i had to have ac, I would just replace the condenser (if your not too good with a wrench get pops to help)
Old Oct 10, 2004 | 07:38 AM
Easy as it may be, you should have the refrigerant drained, change the compressor, then take it to somebody to have it recharged. Unless you have a buddy that is able to do it.
Old Oct 10, 2004 | 10:08 AM
Mooobunnny's Avatar
DO NOT pay $1,200 bucks to have it done. That is INSANE!
Old Oct 10, 2004 | 10:10 AM
Reckless's Avatar
Super Moderator
First, make sure it isn't the compressor. I thought mine had gone out too, but it was a leaking line. There is a place where the line is prone to crack or break. At the top of the condensor, right near the radiator cap, one of the lines connects to the top of the condensor. Take the bolt out with a 10mm socket and inspect the o-ring and fitting. Mine was cracked and allowed the 134 to escape slowly.
Old Oct 10, 2004 | 11:27 AM
Matt D's Avatar
Retired Street Racer
i have a complete ac system i removed off of my 2000 with 49,000 miles...let me know if you want it
