Free ram air mod results???
I picked up almost 1 full mph trap speed from it and cut what might actually be roughly .075 from my ET. But again, the car might've done that on that very next track visit anyway, but I doubt it.
The stock system ALSO pulls air from underneath by the way, just further forward than it is with FRA. There are no true front/bumper air inlets on base Z28s/Formulas/TAs, the air enters after hitting the lip underneath.
Finally, if you don't seal off the front lid/airbox slot (as I haven't) then you will also still get some of that better air from the nose area, though you may then also be losing some of the ram air effect of the FRA as well.
Thanks for the input. Your 1 mph is probably a good number. As far as where the air comes from, it does come from both the front and from below, but the front volume in the nose does a good job of getting the trash out before it goes into the front inlet of the airbox. I would like to see a comparison of the FRA versus raising the airbox. Both increase the inlet area to the filter. As far as engine temps, I doubt that the FRA raises water temps, I was thinking more about the inlet air temp during city driving. Someone posted earlier that they monitored the IAT before and after the FRA and found the inlet air temp was up with the FRA during city driving. That and the fact that the filter does get dirtier, I decided against it.
You are very objective looking at this mod. I find that most people spend the time doing it and they are so proud of what they just did that they just "feel" that it's better. That's human nature, but it's not proof to me that it works. Your 1 mph is the best objective evidence that it actually works. I'd just like to do a mod that doesn't have any negatives anywhere else. My car had a pinging problem when it was hot outside, so I'm very sensitive to anything that raises the inlet air temp.
I am now considering lowering the airbox back to stock and actually sealing the box off completely (other than the FRA area obviously) and see how that works.
And you won't get that much hot air coming into the engine anyways.
I don't think the heat in traffic is an issue, unless you need a few more HP to do a better burnout than the guy next to you on the "expressway"
If you're concerned about the heat, do the FRA and save up for an SSRA.
Damn WS6s have it so good.
