K&N cleansing and Re-oiling
Old Oct 18, 2004 | 04:46 PM
02WS6Bird's Avatar
Default K&N cleansing and Re-oiling
how do i kno if i over oiled it or under oiled it?...i kno it says till all apparent white is covered....but what if some is covered less than others?....how easy is it to over oil?....or does it not really make that bigga diff?
how often should i do this anyway? i kno it says 50-100K but what do yall think/do?
Old Oct 18, 2004 | 05:03 PM
Steve Burger's Avatar
LS1TECH Sponsor
I clean mine once a year. Too much oil will jack up the MAF signal. The excess oil will coat the wires on the MAF and not signal the PCM right.
The way I avoid over oiling is to:
1. Clean the filter per instructions.
2. Wash it out well.
3. Before it is fully dry (Just damp) Oil it. As the water dries it will spread the oil out. It will kind of wick the oil into the gauze as it dries.
I have not had a problem doing it this way and have never over oiled a filter.
Old Oct 18, 2004 | 08:58 PM
Ferocity02's Avatar
I oil it till it's a nice shade of purple, kinda hard to get it right I know, but you can't hurt anything by putting a little too much oil on it, whatever seems right.
Old Oct 18, 2004 | 09:41 PM
LS1LT1's Avatar
Thumbs up
I use a very similar method except that I let it dry completely before oiling it.
When I oil it I use fast strokes across the filter with a thin coat of oil (one side of the filter only of course), let it sit (it will spread or 'wick' this way as well) and then touch up the still white unoiled spots afterwards. I then wrap it in a paper towel and let it sit overnight.
I've never had a MAF problem either.
Well, except for the potential of excess oil getting onto the MAF.
Old Oct 20, 2004 | 07:45 PM
02WS6Bird's Avatar
how often shoudl this be done?
Old Oct 21, 2004 | 12:49 AM
LS1LT1's Avatar
Depends on where you live and where you drive...K&N says every 50k (or is 25k?) miles I think but I would do it more often, say every 10k - 15k depending on how dirty the filter looks.
Old Oct 21, 2004 | 12:54 AM
ls1 1990 VN's Avatar
If your filter looks brown it,s dirty. I clean mine not on milage or time but by color.
