02 sensor question...........
Old Oct 18, 2004 | 09:55 PM
Nasty Hawk's Avatar
Default 02 sensor question...........
I just recently had a Tr 224/224 cam installed. I then sent my computer to East side performance. Everything was fine but i believe a front 02 sensor is bad (back ones are deleted) and know the idle is thrown off and sometimes it will shoot a flame out the back on a cold start when it cant find an idle. i deleted the code once and the car ran perfect but it came back and same problem.. Are the rear 02's the same as the front??? can i just switch them cause the rears are deleted??? or is their aftermarket ones with a wider band that would be worth buying??? please help.
Old Oct 18, 2004 | 10:36 PM
Ferocity02's Avatar
Yes, the rears will work on the front.
