More issues with Fast 90mm TB :(
To test if this is the problem.Grab TB blade and turn throttle Cam and see if it moves.I know it will...
Ill pull it off and look at this again but I already made the flat spot on the shaft and tightened down the TB, I tried to move it and I could not but maybe its moving a minute amount who knows. Plus it only does it when the car is on which is what really perplexes me.
I made the problem occur on purpose 5 times to see what was going on.
Each time I would bring it up to 3k and it would stick I would shut the key off and go have a look. The cable is not binding up. The cam is not hitting anything. I can tap the cam lightly with my hand and it snaps shut. The only thing I can think of would be the blade scrubbing in the bore. I ran out of time last night and I will be messin with it as soon as I get home to get to the bottom of it. I am pissed to say the least.
BTW I also thought of putting another return spring on there. Should not have to do that with a TB that is this expensive. But I will do what needs to be done.
Brad
Brad
I think with a strong enough spring my issue will be fixed.
IF ANYBODY WHO READS THIS WILL BE KIND ENOUGH TO COMMENT, PLEASE INFORM HOW TO DO THE SPRING MOD
Did I say please ??????
Sure enough, the blade wasn't closed all the way- the cam is spinning on the shaft- I can move it by hand in my case.
I previously experienced problems with the TPS sensor, too. I got that straightened out, now this. What a PITA. Also, the bolt holes for the IAC motor were too shallow- I used some washers to correct that problem (I was afraid to cut the bolts) but it looks kinda shitty.
Shouldn't have all these problems with a $500+ TB, IMO...poor quality control at FAST.
Makes you wonder if any testing was done on these units at all before they were released?
Damn man,, well the good news is Jay at fast will get the groove machined in for you so it does not spin on the shaft, But damn man you had alot of problems.
Brad
I'll try revving it up and letting it come back down like you did and see if I can get it to stick that way but mine is like yours in that the blade does not turn on the shaft and the tps is ok. It must be just barely scrubbing in the bore then, We might even try what Jimmy said earlier in the thread and undo the shaft to blade bolts and flich the throttle then re-tighten. At least you were able to actually see it stuck. What I was doing was stopping and turning the car off while it was at high idle but as soon as a I turn the car off its goes normal...!!!!
The Blade is scrubbing in the bore. It has scuffmarks on the pass/throttlecam side.
The blade/shaft has play in it from side to side. I can hold it up to the light and can see a small amount of light peeping through all around except where the scuff marks are. I can tap with my hand on the Throttle cam and shift the shaft/blade so that there is light all the way around. When I rotait the cam the blade moves back over to the wrong position.
This problem is amplified when the motor is at operating temp. I can make it hang by hand now when the motor is warm. It is even hard to open the tb It seems to be getting worse.
I tried a carb style return spring and it did not make any difference.
I know I can send it to FAST and they will fix it. The problem is I have an Appointment for the Dyno/Tuning on Tuesday. The next availiable appointment is not untill DEC. I had to pull freakin teeth just to get Tuesday off so I could make it up there. As of now the car is undriveable.
Sorry Mike, Wish I could have been of more help.
Brad
I want to have this bad boy done so I can drive up to Thunder without having to always **** with the idle, If I cant fix it it will go to fast after that.
Brad
same here so far so good, chalk up some more R&D for us ls1techers
I did get a flat tire when driving today though
if its not one thing its something else.
I then hooked one end of the spring to that peg that sticks out on the cable cam. Hooked the other end to the upper radiator hose clamp.
I also at one time took the throttle plate out and smoothed off some of it to stop that scrubbing in the bore. Be careful here. It's very easy to remove too much material.
I know, this kind of crapp shouldn't be necessary.
Later fellas,
D
He should work at FAST so others in this post didn't have to deal with this.
Or everyone could just ship their TB's to Dustin and let him re-fix them
Good work, Dustin Butts.
Later fellas,
D
Thanks man, if I am still having issues this is the next thing that I will try, one way or the other we are gonna make these TBs fully functional lol.
Mike I hope you can make it to Thunder Man!
I will be making my appt at the dyno tomorrow
Brad
I've also had screwee TPS readings. see my other post. I bought mine in October.
