HELP ... Intake swap > busted sensor > what's it called????
Old Oct 30, 2004 | 07:27 AM
JEB99TA's Avatar
Default HELP ... Intake swap > busted sensor > what's it called????
As things happen, I got up and started swapping my LS1 intake for my new LS6 intake ... lo and behold, I snapped a plastic-sleeved sensor in half, which screws into the top of the engine right behind the intake ... by the driver side coolant plug. Anybody know what it's called? It's about 3 1/2" long and has a metal threaded base that screws into the motor.
Old Oct 30, 2004 | 09:02 AM
JEB99TA's Avatar
Default Never Mind > Got it ...
It's the Oil Pressure Switch ... $22.99 @ Central Auto ... aftermarket.
Old Oct 30, 2004 | 11:15 AM
8-Pack's Avatar
Yep I have always known it as the oil pressure sending unit but same diffrence
Old Oct 30, 2004 | 11:29 AM
JEB99TA's Avatar
Default Different names
I've always heard the oil pump called the oil sending unit, however, the dealership mechanocs this morning called it that and a couple of other things. The GM Book referenced it as the oil pressure switch. One dude said it was the fule sending unit (fule pump) and EVERYBODY looked real weird at him .... LMAO!!!
Old Oct 31, 2004 | 04:18 PM
SSTYCOON's Avatar
that same thing happen to me! when I was doing my intake swap,
use a 1 1/16 deep socket to remove the sending unit
