cutout install location question
Are you saying you want to run one open header?
If you're gonna do one cutout, the only logical place is in the i-pipe where the little cubby hole is..
May aswell put 1 drag radial in the back and swap out one of the heads for a performance head and leave the other one stock
2 on the y-pipe (one on each side) and one on the I-pipe.
the one on the I-pipe gives me 20hp to the rear wheels and the ones on the y-pipe give me 10rwhp each.
so if your going to put only one, go with putting it on the I-pipe
) I just really didn't want to cut and weld onto a $800 exhaust system. But gotta do what you gotta do
I had the one on the I-pipe first, later i just added the 2 on the y-pipe.
You should try to dyno it with the two on the y-pipe open and the one on the I-pipe closed. And then dyno with them all open and see if you gained anything. Wouldn't be that much of a gain, but I am just curious if you would gain anything.
