My SES light is on.
(It also feels good to) But my SES light came on.Doe's anybody know what is up with this. Can this be harmful to my Car?
Al
.thank guy for any help.
.thank guy for any help.could take a volt meter and at the conector of the harness from the the car
put the meter leads on the two brown wires, should be C and D pins i think.
and turn the ign. on, and masure the voltage, should be about 12 volts
if less than 11 volts check the ext. wires or the sensor fuse.
if there is about 12 volts than it is the O2 sensors.
hope that helps.
