P0121 In-Range Operating Throttle Position Sensor circuit failure
P0121 In-Range Operating Throttle Position Sensor circuit failure.
P0404 Exhaust Gas Recirculation circuit rang/performance
I could care less about the EGR code .. I think the tuner just neglected to delete EGR stuff from my computer.
But the TPS one worries me a bit. The ported throttle body I was given from an online shop had a slightly larger pedal than my original '98 throttle body. Does this have to be accounted for through tuning or should I not even be using a throttle-body with a larger pedal? I've also read that the computer simply just throws this code after a cam swap and tune, which I had done before my recent trip to the shop, and has to "learn" the tune. After the initial install of my cam and tune I did get an SES light, but it disappeared before I got a chance to scan it .. and I'm thinking it may have been the same P0121 code.
Your thoughts?
Thanks,
Sean
