Looking for a header setup that don't leak. ><
Old Nov 9, 2004 | 03:48 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Looking for a header setup that don't leak. ><
I'm tired of the leaking from this slip-fit crap design on my hooker lt's. I was looking at the mac mids because I had a set of their lt's on my mustang and the ball socket seats great and comes apart easy for removal. But it seems they are a tad small for ls1's. I also want a cat ypipe. So what are the options?
Old Nov 9, 2004 | 09:11 AM
mySStery_machine's Avatar
Kook, QTP and others if you want the quality and stainless steel. I personally am going with Kook LTs and catted Y down the line sometime soon. Check JRP's sticky on exhaust in the commonly asked questions it's a sticky in the new LS1 section.
Old Nov 9, 2004 | 10:03 AM
conan's Avatar
What was said In ubove statement. Just get the good band clamps instead of "U" clamps. No leaks here.
Old Nov 9, 2004 | 10:48 AM
Jeff2002WS6's Avatar
Napa sells some nice 3 inch stainless steal band clamps. Try those with some copper RTV. No leaks here.
Old Nov 9, 2004 | 11:40 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I've had problems with my stainless band clamps leaking, so I'm gonna try a new style clamp in December by the name of a Pi-thon Firelock. I posted on here a while back about them, but I'm gonna see if they work as well as they should (very $$$).
Old Nov 9, 2004 | 01:10 PM
GM Muscle's Avatar
Did you try and use your band clamps more than once? I find that they strech and leak after retightening them a couple of times.
BTW: Check out the Walker band clamps, they come with this black goo on them that seals up the joint really good. Also, Jeg's makes prefomed band clamps and I've found that they work awesome for slip fit applications.
Old Nov 9, 2004 | 02:23 PM
KJ's Avatar
KJ
If you need a set of band clamps let me know. I have them in stock from Kooks for $10.95 each. If you are wanting a complete different set of headers and a Y pipe I can offer you Kooks, Dynatech, and most all the other major brands. Let me know if I can help!!
Old Nov 9, 2004 | 02:37 PM
REDLV SS's Avatar
I just had my set-up flanged at the headers and at the catback. This way I can still take the y-pipe down. Haven't had any problems going this route and used the copper flange gaskets with good success so far. This is another option instead of band clamps. Good luck
Old Nov 9, 2004 | 03:12 PM
MeentSS02's Avatar
Yep, I've even used an impact wrench when I got pissed at them, and still no luck. I think the slip fit was just a bit too loose on the driver's side, but who knows.
I'm gonna go a different route and see if it works...if not, I'll be sad, poor, and STILL have a leaking exhaust.
Old Nov 9, 2004 | 05:34 PM
GM Muscle's Avatar
Did you try tightening them to all different specs? Most stainless ones are suposed to seal at 50-80ftlbs. That'd suck if you can't get them sealed good.
BTW: Where did you see the Firelock clamps? I'd like to check them out. I'm always taking my exhaust off at the track and I go through band clamps like crazy. I'd like to find some reusable clamps. Since you have a slip fit and not a butt joint the preformed Jeg's clamps might do the trick.
Old Nov 9, 2004 | 05:54 PM
Brian2001SS's Avatar
My TTS headers don't leak at all.
Old Nov 10, 2004 | 12:54 AM
AzzHauler's Avatar
Hooker supplied thin band clamps that were barely better than u-clamps. I got the 3" ones from NAPA. These firelock ones supposed to be better?
Old Nov 10, 2004 | 08:41 AM
MeentSS02's Avatar
I actually have one Firelock clamp already from Pi-thon (the only place I think you can get them), and it is sitting in my closet at home. There will be three more coming shortly, so I'll have 2 3" ones and 2 2.5" ones. I recently put a deposit down and made an appointment with Speed Inc. to do their custom over the axle true dual setup, and I'm gonna have the 3" Firelocks at the header collector and the two 2.5" ones right before it goes over the axle.
My goal is to be able to easily drop the center section for clutch changes, etc, but it should also leave me with a fair amount of flexibility. I should be able to have some short dumps fabbed that could hook directly to the header collectors so I could run open headers, and I could easily have some swappable cats should the need arise. I really like the Firelock's design, as it only requires a butted connection (although they do make one for a slip fit connection), and they tighten very well with two spanner wrenches, and release even easier.
Don't kid yourself, these things aren't cheap (not like my exhaust will be anyways). I posted a thread about it before, but I've since taken the pictures down on my hosting site. If you want me to post them back up, I would be more than willing to accomodate you. They aren't even remotely like band clamps, and I'm hoping they work as well as they should.
Here's a link to see what I'm talking about:
http://www.pi-thon.com/Firelock.htm
Steve
Old Nov 10, 2004 | 05:14 PM
Hardtop00SS's Avatar
Yea my QTP's/Mufflex Y is leaking and I've used those SS band clamps from NAPA, but they still leak some, was thinking of going with the 3bolt flange style in the future, or maybe the ball/joint combo like on the Mustang's to see if that works.....
Old Nov 10, 2004 | 05:22 PM
GM Muscle's Avatar
I sometimes use the NAPA SS bands and they are about the worst on the market as far as leaking goes. Try the Walkers they are about the best I have found (Summit should have them).
MeentSS02: Once you get your exhaust done post up how you like the clamps and everything. They are expensive but if they are reusable they are worth the money. I figure every time I take my exhaust off it cost about $25.
Old Nov 10, 2004 | 08:28 PM
98 Silver Bullet's Avatar
I had problems with my Jet-Hots. I finally had a 3 bolt flange welded on both. I can have my exhaust (true duals that dump before the axle) off in about 15 minutes.
Old Nov 10, 2004 | 09:15 PM
tomaSS's Avatar
That's what I did too. I don't care what anybody says, band clamps will leak.
Old Nov 11, 2004 | 12:31 PM
MeentSS02's Avatar
Will do...I'm really hoping these things work well. It is just too much money for them not to.
Old Nov 11, 2004 | 01:05 PM
777's Avatar
777
i think you should just get your headers flanged...that shouldn't be very expensive...and you will definatly not have leaks...
