Advantage of corvette oil pan
Old Nov 14, 2004 | 07:10 PM
Argon Z's Avatar
Default Advantage of corvette oil pan
What are the advantages of a corvette oil pan.
-How much shallower is the oil pan?
-Does someone have the measurment on both a camaro pan and a corvette pan, from top surface that mates to the engine, to the external bottom of the oil pan.
If i use a corvette pan i would be able to drop the engine closer to the ground, thereby lowering the center of gravity.
Thanks
Old Nov 14, 2004 | 11:10 PM
LS1LT1's Avatar
Lightbulb
I don't think you can use the C5 pan with an F-body platform (and vice versa)...K member clearance issues etc.
Old Nov 15, 2004 | 08:31 AM
Danny2tek's Avatar
