Easy one .. how to change belts
Old Nov 19, 2004 | 06:11 PM
Jpr5690's Avatar
Default Easy one .. how to change belts
ok its a basic question but im not sure how to do it does anybody wanna give some advice ortell me where theres a how to on changing the 2 belts
Old Nov 19, 2004 | 06:17 PM
WILWAXU's Avatar
15mm wrench. Retract the tensioner and pull it off.
Old Nov 19, 2004 | 06:26 PM
Jpr5690's Avatar
simple enough ... thanks
Old Nov 19, 2004 | 09:43 PM
ls1_doc's Avatar
it is WAY easier to do it from under the car if that is an option
Old Nov 20, 2004 | 01:25 AM
TheBlurLS1's Avatar
That's what she said...
well you have to do it from above the car, w/ a 15mm (use a cheater bar if you're by yourself, easier to hold). then crawl under it and do the same to the a/c tensioner pulley.
dont forget to put the a/c belt back on FIRST or you will be screwed
