Electric cut out?
Old Nov 20, 2004 | 05:44 PM
INTENESS's Avatar
Default Electric cut out?
I have the QTP cutout what wire do I use to hook up for the power for the cutout? my car is a 01 m6
Old Nov 20, 2004 | 10:46 PM
Slammed-am's Avatar
I beleive you have to splice into a wire to leech the power. I think you have several choices though. Do a search to find some more info.
Old Nov 20, 2004 | 11:22 PM
dlandsvZ28's Avatar
I tapped into hot wires to the extra power supply.
Here's a tip.
Make sure it works before you mount it under the car. It's a lot easier to diagnose the switch and measure closing/opening time with the unit in your hand than installed in the exhaust system. Mine had a loose connection in the switch and didn't work.
I installed an on/off switch and power the unit through it. Hit the on switch and the unit has power. I didn't like the idea of having power to the unit 100 percent of the time.
I also thread-locked the screws and sealed the unit with silicone sealant.
Old Nov 21, 2004 | 12:09 PM
M6HuggerSS's Avatar
i used the traction control switch....i think its the pink or purple wire....
Old Nov 21, 2004 | 02:07 PM
Durien's Avatar
i tapped into the pink TC wire..
you are going to have so much fun with it...
i never get tired of playing with my QTP electric cutout..lol
