Do Hooker LT's and Jet Hot LT's line up the same?
Old Nov 21, 2004 | 09:30 PM
Mike94ZLT1's Avatar
Default Do Hooker LT's and Jet Hot LT's line up the same?
Hey guys, I have hooker longtubes on my car, I bought them used and they weren't in the best shape when I got them, and now they're much worse. Anyways, I want to replace them but I was thinking of going with the Jet Hot brand headers instead because I have heard they are higher quality. My question is will the exhaust I have now line up or will I need to get it redone? Also, is there any header for LS1's that come with a 3-bolt flange, or do you think I could sweet talk jet hot into welding the flange onto their headers before coating them? Thanks!
Old Nov 21, 2004 | 09:34 PM
jrp's Avatar
jrp
SN95 Director
yes they are the same. also i wouldnt have a flange welded up unless you send them your y pipe as well. otherwise how are they going to know where the holes line up
Old Nov 21, 2004 | 10:12 PM
Mike94ZLT1's Avatar
My exhaust guy could take care of that, plus if you get the Hooker reducers they have a loose 3 bolt flange around them and the end is flared so it wont slide off. A gasket goes between the header flange and the h-pipe (no single exhaust here) and all is good! Thanks for the info!
