ASP pulley leak?
Old Nov 22, 2004 | 08:19 AM
4u 2 nv's Avatar
Default ASP pulley leak?
my ASP crank pulley has been on around 6000 miles. its starting to leak now. any one else have this problem? should i put the old one back on? can i reinstall it and see if that works? thanks
Old Nov 22, 2004 | 08:24 AM
Squintz Palladoris's Avatar
Sounds like the seal in the timing cover that the pulley slides into.
Brad
Old Nov 22, 2004 | 08:49 AM
4u 2 nv's Avatar
so what can i do?
Old Nov 22, 2004 | 08:59 AM
Look where the pulley goes into the timing cover. See if it looks like thats where you leak is coming from.
If it is you need to remove the pulley and replace the seal.
Brad
Old Nov 22, 2004 | 09:00 AM
Awesome Sig BTW!
Brad
