How do I remove a starter on a 98 A4?
Old Dec 13, 2004 | 09:30 AM
tici's Avatar
Default How do I remove a starter on a 98 A4?
As in the title.
I wanted to remove my starter but I can't insert a socket to the lower bolt.
There isn't enough space between the bolt and the plastic cover located between the engine and the starter.
Right now I should brake the plastic
The transmission oil line are in the way also.
Who did this job already? How?
I know, it's not difficult at all but I really can't get that bolt out. I tried a wrench but it's too weak: the bolt is probably locked and really need a socket to come out.
Thanks - Stefano
Old Dec 13, 2004 | 02:59 PM
Damage Inc.'s Avatar
Sweet Cheeks
Try a 3/8ths drive socket. It has a thinner wall than a 1/2" drive. That 15mm will fit right it with a little persuasion.
Old Dec 13, 2004 | 06:13 PM
tici's Avatar
Good idea, I'll give it a try.
I was also thinking to warm up the socket "a little" to melt the plastic right there where it needs.
Not an elegant solution but better than cut the plastic.
Old Dec 14, 2004 | 08:52 AM
Sweet Cheeks
There's no need to melt anything. The smaller socket will work, it just takes a little muscle. I've done it on a 98 before. That's why they went to 13mm the next year and every year after.
