welcome to my nightmare
so can i get the pan out and back in with the tranny/flywheel/bellhousing removed or what?
there doesnt seem to be a part number on it, only some wierd markings and the number 13. there is also what looks like a production date marking but im not sure. its 2 circles, one inside the other, between the circles is a bunch of dots, and in the center is the number 01. maby it is maby it isnt?
anybody have any idea on how to identify the updated slave vs. nonupdated???
i've been researching and figured out that there is about 2" of dipstick tube still in the motor, maby i can lower the oilpan enough to yank it out thru the inside? however long it is from the top shoulder on the dipstick tube to the bottom (im guessing 2") is whats still in the block.
we have some ease-outs we are going to try now. i'm going to get one started, then see if i can spin it in its hole, then im going to penetrating oil the **** out of and spin it a bunch of times, then try to keep spinning/pulling out. i'm guessing its just corroded to hell and needs to be free'd up. i'll take the oilpan loose if that fails and seewhere i'm at.
turns out that there is about 2" left in the motor, maby i can lower the oilpan enough. i have to find out now if the block is step machined or not, because it might not be able to slide thru into the oilpan.
Good luck.
Charlie
*Edit* didnt read your post right above, looks like you already got the easy-out idea!
i dont know HOW THE HELL it was stuck so good in the first place.
i also got slide hammer from autozone as well as the pilot bearing tool for it, and popped that bad boy out. im going to reassemble the trans tomorrow, then change my motor mounts out, then put my exhaust on.
thanx for boosting my spirits on this and responding to my posts guys!
I didn't read all the posts, so some or all of this may not help - but here it is anyway.
Good luck.
Good luck.
