my y-pipe is knocking
Old Dec 25, 2004 | 05:05 PM
L-SS-1's Avatar
Default my y-pipe is knocking
got a JET-HOT ORY and on a hard launch it hits the floorboard when traction control is on, but not when its turned off. I also have a MUFFLEX support bracket that is supposed to prevent this but it doesnt. So i'm curious is this just a traction control thing or what?
Old Dec 25, 2004 | 05:45 PM
Keenov's Avatar
Where is it knocking? And is the bracket placed where it is knocking?
Old Dec 25, 2004 | 11:01 PM
Full-Force's Avatar
That makes sense to me. When traction control is on it is not a smooth cutback of power but rather abrupt causing the engine to move around alot. I am willing to bet you are running stock motor mounts. If so get'em off and get you some prothanes. It will tighten up the whole car and keep your exhaust from moving as much because the engine wont be moving as much.
Old Dec 25, 2004 | 11:02 PM
Full-Force's Avatar
One more thing. I see you have a 6 speed. I bet your stick moves when you get on the gas too. Motor mounts will take care of that.
Old Dec 25, 2004 | 11:48 PM
01TAFlyer's Avatar
Are motor mounts something I could do by myself, somewhat easily?
Old Dec 26, 2004 | 12:54 PM
L-SS-1's Avatar
thats another thing, mufflex said to put it on the driver side. it hits on the passenger side. i don't understand how it helps putting the bracket on the driver side
Old Dec 26, 2004 | 12:58 PM
LS1_PNYTAMR's Avatar
hmm my mac hits the underside of the car just crusing around, anytime it gets b/t about 3-4 thousand rpms it slaps and rattle against the underside of the car. i have no idea how to fix mine
