Old Dec 27, 2004 | 10:53 AM
blown02ss's Avatar
Default ???????
I have a 2002 Slp camaro ss.With the centermount. Well i took my stock exhaust off and replaced it with the loundmouth cat back. Then i put a 3inch slp ypipe on and it feels so much stronger. What should i run now?
Stock i ran a 13.3@105 so what should i do with the exhaust and ypipe
Old Dec 27, 2004 | 11:22 AM
MeentSS02's Avatar
Kleeborp the Moderator™
If I had to guess, under the same track conditions, you should run about a 13.2 @ 106. The exhaust you replaced was actually a fairly free flowing exhaust.
Old Dec 27, 2004 | 07:20 PM
Gloveperson's Avatar
the CME and the loudmouth flow basically the same as meentss02 said. Sell the CME, a lot of people would want that.
I'd say, you will run just a tad better than you did before under the same conditions, although the car has a lot more than a 13.5 in it stock
