Installed FAST 90 TPIS 90 Tbody...got problems
Ok Kurt, what kind of info did they give you about the right left throttle blade movement fix?
but the spring helped mine alot I still want to get rid of the spring just because it looks like crap and I don't think we should have to slap the throttle every once in a while to bring the rpm's down on a T/B thats so pretty and $$$.Elec. water pump
The problem with a sticking throttle on an f-car is the only thing that centers the blade is a press fit on the shaft bearings. so if the cable pulls at an angle it will force the shaft to one side. We most certainly want to supply the finest tb's. It would help if you guys would see if your cable is pulling at an angle or not. Then please call and let us know.
Myron c
952 448 6021 We are closed today, Happy new year all
it cold and hot starts "decent" now, but not perfect, on the way to work it did not hang once, on the way home from work it hung at 2000 a couple times and i had to slap it shut with a pop of the pedal, so i figured id jack the screw up a lil more, now in parking lots and such when i start it up and first give it gas and let off it will hang at like 1500 and like the iac brings the idel back down to idle....reason i say that is cuz it hangs at 1500 only for a few seconds and then bam idle.....and suggestions
it cold and hot starts "decent" now, but not perfect, on the way to work it did not hang once, on the way home from work it hung at 2000 a couple times and i had to slap it shut with a pop of the pedal, so i figured id jack the screw up a lil more, now in parking lots and such when i start it up and first give it gas and let off it will hang at like 1500 and like the iac brings the idel back down to idle....reason i say that is cuz it hangs at 1500 only for a few seconds and then bam idle.....and suggestions[/QUO
It's time for you to call me 952 448 5330 myron c
Myron c
Happy New Year!
Joe
Happy New Year!
Joe
Scott
open the throttle wide and see if the shaft will move back and forth easily.
let me know what you find.
mc
mc
It look's like TPIS is really trying to get this straight for us so good luck, if you ever make it over to the Rod Run in Pigeon Forge I go in the spring and fall maybe I can check your ride out.
Later
Joe
mc
mc
Joe
