Sweet Thunder PICS
Old Dec 30, 2004 | 04:48 PM
Croaker's Avatar
Originally Posted by VSGLS1
I can't wait to get my Sweet Thunders here so I can get some more ground clearance over my 40 series Flowmasters. I also had Intrax springs when I first did my 3" duals...it will not work! Change them before you go duals. I am also going to be ordering the ground control kit next week.
How close was it? Will 2.5" work? I really want to leave the car at the height it's at now, but I also won't settle for any exhaust that isn't a true dual setup. Where's the low part of the system?
Old Dec 30, 2004 | 07:56 PM
M6HuggerSS's Avatar
cool man that set up looks bad ***..... a sound clip would be nice.....
a bet you also saved about 40 pounds in the rear......
Old Dec 30, 2004 | 11:55 PM
5POINT7's Avatar
I finally got a vid with sound but I need someone to host it for me. Can anyone help? Thanks
Old Dec 31, 2004 | 01:24 PM
black_z's Avatar
search for LS1 Sounds. You email it to him and hell permanently host it on his site.
Old Dec 31, 2004 | 06:18 PM
777's Avatar
777
Old Dec 31, 2004 | 08:08 PM
VSGLS1's Avatar
You will have an easier time with the 2.5" system. Plan on adding headers with it that low?
Old Jan 1, 2005 | 01:30 AM
Croaker's Avatar
They're the reason I'm going TD - 1 3/4" Grotts w/ 3" collectors. Coming off Roman's car (lowered) and he doesn't touch, so I think I'm alright up front...although I might swap in the stock springs before the TD install and then check clearance, just to make sure.
Old Jan 1, 2005 | 09:28 AM
69_YENKO's Avatar
5point7, no wonder you didnt have clearance before, with the bullets angled out like they where i but the almost touched the ground. I have my TSP duals running along the trans tunnel, they wont fit down into it like the sweet thunders do but it works pretty good.
Where is a good place to order them from? i think im going to swap out my bullets as well.
Old Jan 1, 2005 | 04:26 PM
Krab's Avatar
5point7, in the pic of your exhaust, I noticed the torque arm mounted on the passenger's side. Is that how the BMR torque arm is mounted, or am I seeing things? Mine is mounted on the driver's side, but it is stock.
Old Jan 1, 2005 | 04:58 PM
Croaker's Avatar
I don't have a definitive answer on that, but note that it's mounted on opposite sides from one picture to the other, if that helps you out at all.
Old Jan 1, 2005 | 08:11 PM
5POINT7's Avatar
69YENKO, you can just google "sweet thunder mufflers" to find their website and order from there.
As far as the torque arm. My torque arm is on the driver side just like all the others, I accidentally flipped the pic in photoshop while I was lightening it up. Sorry about that guys.
Old Jan 2, 2005 | 12:16 AM
  #32
LS1_PNYTAMR's Avatar
what do ya'll think about 1 sweet thunder 18 inch muffler at the end of my 2.5 inch mac ypipe???
