is it worth it to upgrade ignition?
Old Dec 30, 2004 | 11:32 PM
WS6FirebirdTA00's Avatar
Default is it worth it to upgrade ignition?
i will be making about 450-470 on heads and cam and all bolt ons hopefully and reving to 6800, should i look into upgrading the coil packs or getting maybe an msd ignition or is the stock pleanty??
Old Dec 30, 2004 | 11:45 PM
Z28Venom's Avatar
Ignition...
Revving that high on a 2000. I'd be more worried about my bottom end..
But to answer your question, you don't really have anything to worry about with your ignition. Its more than enough.
Old Dec 31, 2004 | 10:31 AM
slow's Avatar
not until you add a couple hundred hp would i worry about the ignition, and then i would just go with the truck coil packs.
Ryan
Old Dec 31, 2004 | 10:41 AM
cyphur's Avatar
Ryan
why truck coil packs? whats the difference?
Old Dec 31, 2004 | 11:09 AM
D Rock's Avatar
Truck coil packs are known to deliver a little bit bigger spark.
Old Dec 31, 2004 | 12:14 PM
why would you be worried about the bottom end. max rpm will be 6800 but itll prob only see 6600, its only 400 more than now
