true dual
https://ls1tech.com/forums/showpost....11&postcount=6
Regardless of semantics, the point I'm trying to make is that when people move up to aftermarket exhaust setups, especially when they get to the level of headers and cats or lack thereof, they will sometimes lose that low end responsiveness that they originally had, and want it back. We are all making a compromise when we do these upgrades. I wish my car had the low end feel that it had when I had just manifolds, but it doesn't, even with Kooks LTs and a custom over the axle TD setup (no cats).
just at everyone who needs backpressure. that writeup is very informative and it makes alot of sense. all that is required in an exhaust setup to scavenge is a few inches past the header collectors. sure, an X pipe would help pull the gasses out, but not as much as a properly tuned header.
I've seen on two occasions, two totally different set-ups. One, big heads/cam, one alot of spray. The heads/cam car had been tuned for open headers and picked up 30 rwhp and 30 rwtq in the mid-range with a 3" true dual system, Dr Gas X, and 18" Flo-Pro Twister mufflers - over tuned open headers(FLP's). Peak numbers were nearly identical.
The other car had duals out the back with two mufflers on each side. The system was 3" to the X and 2.5 right after with four Magnaflow bullet mufflers total. He decided to do two cutouts just past the collector and lost 15-25 rwtq in the mid-range. Peak power was basically the same.
Open headers sound very free flowing, but the engine is still just pushing exhaust gases out of the head - as opposed to them being pulled out by a good crossover...
backpressure is a build up due to a restriction. in the case of exhaust, it's when the diameter of the pipe can no longer expell the amount of gases introduced into the system. the higher the rpm, the more volume of gases that need to be gotten rid of. so you increase the diameter if the pipe to do this. but theres a cost. you start to trade low speed velocity for high speed velocity. also power output and cid comes into play as well. it's the whole squeeze the water hose trick.
same goes with the diameter of headers.
you don't need backpressure. you need correct diameter of all the pipes to keep the velocity of the exhaust pulse up. the faster the pulse travels, the more you can get out. and with the speed of the pulse, it creates a vacuum behind it. this in turn helps to extract the next pulse behind it.
we could also get into how keeping heat in the pipes helps the velocity as well if you want.
I absoloutely agree. my point was just that all a properly tuned pair of headers needs is a little extension past the collector. but that wasnt what i was focusing on, it was the whole backpressure thing.
hp is merely a function of torque. all its good for is car advertisements and bench racers.
for you huggerorange you made a good choice, with a cam you should see an improvement over a ory set up.
for the people who are stock internally you wont see much of an improvement if any over a good ory set up. Unless its weight savings and sound you are looking for, then td's would be a perfect choice.
<---Picked up 24 rwhp at 5000-5500 over a custom 3" open Y, and almost as much torque - stock internal.
Took the weight savings as gravy...
