Help Please!!!!!!!
Old Jan 5, 2005 | 07:56 PM
SSilverSSurfer's Avatar
Default Help Please!!!!!!!
im on the freeway... i gun it...BOOM got good take off...once i hit 80...the speedo needle stops at eighty...so does the RPM needle. it stops at 4000and doesnt want to move no matter how much gas i continue to give it. only thing i can think of is the computer is pulling timing. then i have to let off gas and then hit it again for it to go. iono. its weird.
Old Jan 5, 2005 | 08:29 PM
LS1_PNYTAMR's Avatar
wow lol.. sounds like what happened when i burnt up 4 shitty plugs spraying... car was running on 4 cylinders, woudn't go more then 40mph on the way home from the track and made all kinds of shitty noises lol.. but ur not spraying, perhaps it is the computer, but im thinking ignition! does it do this all the time now, or just above 80mph.. or does it do this at 4000 in every gear now since its started?
Old Jan 9, 2005 | 12:49 PM
it does it at 4000rpm at 80. only when i punch it. it sounds like constant bogging
Old Jan 9, 2005 | 12:53 PM
Caribe's Avatar
Check all your spark plug wires, make sure they are on right.
Old Jan 9, 2005 | 01:11 PM
code4's Avatar
Can you take it above 4k rpms in lower gears? Does it seen like it's running perfect except when trying to go above 80mph?
