LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III External Engine (https://ls1tech.com/forums/generation-iii-external-engine-6/)
-   -   Optima Red Top Battery - doesn't fit :( ! Help ! (https://ls1tech.com/forums/generation-iii-external-engine/258835-optima-red-top-battery-doesnt-fit-help.html)
RahuL Jan 7, 2005 01:39 PM
Been struggling to fit the Red Top on my TA.. but it just keeps sliding around.. :mad:
How'd you guys put this thing on ?
RahuL Jan 7, 2005 01:42 PM
ok, just looked this up...
http://192.132.24.107/UsingOptima/height_WCM.asp
looking under GROUP 34/78 [even though we use Group 75/35] we need a puck adapter ? Where can I get that ?
Any other way to do this ?
Tom99SS Jan 7, 2005 01:45 PM
Depends on which RedTop you got. If you got the 75/25 use your battery hold down rubber clamp used for the original battery. If you got the 34/78 you will need a special puck from Optima. Call them and they will send one out. They sent one out for my YellowTop I use in my Tahoe (tailgating and running a powerinverter to power things, got to love those Optima).
RahuL Jan 7, 2005 01:48 PM
I got the 75/35, but the OEM battery hold down rubber clamp bolt doesn't work.. I tried a different bolt, which did fit but the battery sits very loose and moves around :cry:
Tom99SS Jan 7, 2005 01:50 PM
Call me (630.917.6107) maybe I can describe what I did
Tom99SS Jan 7, 2005 01:53 PM
Is this the one you got?
http://www.optimabatteries.com/publi..._25_082304.pdf
Tom99SS Jan 7, 2005 01:56 PM
Also, if you are using the height adapter, DON'T. This maybe why you have the problem. If you are using the height adapter then remove and use your original bolt. That is what I did.
RahuL Jan 7, 2005 02:11 PM
yeah that's the one... I was calling you but my cell phone's battery died ... go figure :eyes: just my friggin luck lol
all I have is my laptop with a wireless card and I'm on lunch break doing this..
anyways, I didn't use the height adapter .. I used another bolt that did fit but the lip on the rubber clamp won't hold the battery firm so it just moves around..
So, yours sits tight with the stock bolt ?
RahuL Jan 7, 2005 02:12 PM
http://192.132.24.107/images/usingOp...ptimaThree.gif
I think I might need that adapter..
The optional puck adapter is required for most GM installations where the side terminals are used.Position the puck against the center cylindar of the battery and bolt to the battery tray as shown.
sixvi6-camaro Jan 7, 2005 02:33 PM
forget the stock garbage completely. Get a year one battery hold down strap. it works great and the battery will never move around. If you take the car road racing or auto X the stock plastic tray always ends up breaking or comming loose.
year one part # BHFBLK its $16 and they are a sponsor too----->
I can snap a pic of mine if you are interested in seeing how it looks installed.
edit.. my old 95 camaro I had the same optima battery with the height adapter and year one strap. it worked fine. my LS1 though has a plain old battery with the same strap an dit still works fine.
ddelallata Jan 7, 2005 02:57 PM
maybe your battery tray/coolant reservoir is broken. Mine was broken at the front lip so I got a new one from the dealer. Have a look at the tray with the battery removed. I went to several salvage yards and all of their f-body battery trays were broken. apparantly this is a weak spot on the tray.
Tom99SS Jan 7, 2005 03:25 PM
Good point. Make sure the front of the battery is in the lip. This holds the front and the rubber clamp holds the back. Factory clamp works for me and battery does not budge.
01 Red WS6 Jan 7, 2005 05:54 PM
Can you snap a pic for us? I'm interested in getting something new for the old car
sixvi6-camaro Jan 7, 2005 08:38 PM
Yes they all break there. My new LS1's was broekn when I bought it. I grabbed the Year one hold down right away. I'll snap a pic in a few minutes I left the digicam on acident and ran the battery down gotta let it charge for a bit. then snap the pic.
Z28Venom Jan 7, 2005 08:40 PM
My redtop came with the clamp specifically for our cars.
sixvi6-camaro Jan 7, 2005 08:58 PM
1 Attachment(s)
ok here's the pic. the strap goes across the top of the battery and mounts keeping the stock hold down still in place. the top mount goes into a threaded hole that is already on the car.
https://ls1tech.com/forums/attachmen...id=21106&stc=1
01 Red WS6 Jan 7, 2005 10:03 PM
Thanks for posting the pic, I think I'm going to pick one of those up
LawmanSS Jan 7, 2005 10:50 PM
Ditto...I wasn't even considering anything like this, but after seeing that pic, it makes me think I need one...hmmm :)
RahuL Jan 8, 2005 12:45 AM
Update!!
ok guys, I went to Pep Boys [yeah! :P ] after work and they had a 34/78 Red Top with the supplied clamp for GM cars... and the 35/75 Red Tops didn't! :guns:
So, anyways, I got that clamp [puck adapter] and finished the install... was easy with the said adapter :nod:
that looks like something we all could surely use... Which of the sponsors has it ? I'm buying one.. just in case!
Finally, after all this hassle.... the damn voltage still hovers around the yellow mark [ just below 13V ] at idle!!! :bang: :bang:
So much for a new battery!! :eyes: atleast, it looks pretty!! :jest:
Thanks for ALL the responses guys... ya'll are the best!! :cheers:
RahuL Jan 8, 2005 12:49 AM
Here's what lead me to change the battery in the first place!
https://ls1tech.com/forums/generation-iii-external-engine/257547-battery-power-drops-after-pulley.html
As soon as the fans kick on [ 168* first fan, 172* second fan ] the volts drop from 13 to the top of the yellow mark!.. even with the new battery!
© 2026 MH Sub I, LLC dba Internet Brands
