Battery power drops after Pulley ?
[ 10-11 .. my guess ] As soon as I give it some gas, it goes past 13 and stays there until I come to a stop..
Just wondering if my battery's taking a dump ? Should I just change it because of age ? If so, replace with what .. stock, Diehard, Optima Red Top ? ... Does the Optima fit w/o any issues ?
I still have the stock stereo, but I might upgrade to some better speakers and amp/subs later on.. but no huge power sucking stuff..
I added an Optima at the same time as the pulley. So that I would have to deal with the problem you're having now.
Time for a new battery.
My recommendation: Go with a yellow top Optima and if you sit for a long time in traffic, put it in neutral.
Just curious, did you do the crank and alt kit or just the crank kit?
Next question is, what part number ?
This is what I got from the Optima website for the 96-02 Firebird V8 5.7L
Part # RED 75/35
CCA - 720
Group Size - 75DTO
Height Adapter Required - http://192.132.24.107/UsingOptima/height_WCM.asp
Is that battery and adapter the correct one ?
My A4 idles at 900 (warrm, and 1050 cold) so I never saw any voltage problems.
Bad30th
Bad30th
... the car's idle was upped to similar as Bad30th's ... 1k @ cold and ~ 850 @ warm not because of the pullies, but because the rpms were fluctuating between 550-800 rpms since the TC was done.. I suppose it IS the battery..
I didn't get the ALTY pulley because I was told it's not needed on an A4 ..
I also just remembered that the turn indicators slow down to almost a pause [blinks once every 2 seconds, as opposed to once per sec when I see 13+V]
However, the car starts very briskly, cold or warm!
Now, I'm wondering where to get the best price on the Red Top.. Autozone has it for $119.99 , Advance Auto Parts for $124.99 ... Any ideas ?
The Redtop is usually $115-130 everywhere. Some of the major mail order companies will put them on push lists for under a $100 but I have only seen that a couple of times in the past few years (that's how I got mine). I would just pick up the one for $120 and not look back, they really are a good battery for the money.
it's a little weird to see the dash lights brighten up when stepping on the gas but otherwise, i've never noticed any real problems with the lack of voltage.
I just installed a Hawker lightweight battery on Saturday and I thought I saw the headlights dim ever so slightly at idle versus giving it some revs, hope it's ok to use the small battery full time, or in my case limited weekend use/racing only at most.
As soon as the fans kick on [ 168* first fan, 172* second fan ] the volts drop from 13 to the top of the yellow mark!.. even with the new battery!
