Battery power drops after Pulley ?
Old Jan 8, 2005 | 03:07 AM
DeepBlueZ's Avatar
Originally Posted by BlownGTX
ok guys, I installed the new battery [ Red Top 35/75 ] but still have the same problem!...
As soon as the fans kick on [ 168* first fan, 172* second fan ] the volts drop from 13 to the top of the yellow mark!.. even with the new battery!
sounds like its time for a different alt. pulley.
Old Jan 8, 2005 | 09:14 AM
GM Muscle's Avatar
Correct me if I'm wrong but the voltmeter in the car only reads the output of the alternator, right? So the new battery wouldn't change anything it will just be able to handle the cycling alot better than the stock one. I've had the same probelm as you for along time and everyhting has been fine, I wouldn't really worry about it. If you can get an alternator over drive pulley but then you might read high when the fans and lights are not on.
Old Jan 8, 2005 | 01:18 PM
JamRWS6's Avatar
It was probably good to replace your battery due to age.....but that wasn't your problem.
You need the alternator OVERDRIVE pulley to fix your charging problems.
Old Jan 8, 2005 | 02:34 PM
SmokingWS6's Avatar
Definately get the Alternator pulley with the underdrive. Crappy battery or even an optima your voltage is still going to drop at idle in most cases w/o the alternator pulley. I just replaced the stock battery in my 98 also, I put in a Delco professional since I have a dealer discount on parts.
