AIR gaskets
Old Jan 13, 2005 | 05:10 AM
kraut187's Avatar
Default AIR gaskets
Does anyone know where I might be able to buy some AIR gaskets? The stock ones look pretty trashed. Thanks in Advance
Old Jan 13, 2005 | 08:42 AM
98Z-6Speed's Avatar
Any GM dealership, they are like $1.50 for two.
Old Jan 13, 2005 | 09:22 AM
SLPSS01's Avatar
GM part no. 12553617
Old Jan 13, 2005 | 11:30 PM
kraut187's Avatar
Thanks a bunch guys.
Old Jan 14, 2005 | 05:10 PM
kraut187's Avatar
Also anyone know how to get more of those bolts(the AIR ones) or what part number they are? Thanks
Old Jan 14, 2005 | 05:22 PM
santino04's Avatar
Instead of gaskets Ive seen some guys just use High temperature RTV sealant as a gasket. I myself used the gaskets, I trust them more than liquid sealants, especially when it will be seeing very high temperatures. Paranoid I guess! As far as locating the gaskets gm dealer or most ls1 performance shops carry them if one is in your area. I would check there for the bolts too, or the hardware store. Good Luck
Old Jan 14, 2005 | 05:41 PM
NO-OPTION-2002's Avatar
Hello,
AIR bolt GM Part # 12556127 $2.42 Retail.
They are M8 x 1.25 thread pitch x 24mm long.
Hope this helps!
Old Jan 14, 2005 | 09:13 PM
kraut187's Avatar
Originally Posted by NO-OPTION-2002
Hello,
Hope this helps!
Immensely thanks,
I'm getting this crap tuned out of my car tomorrow hopefully that fixes a majority of the issues. Wish me luck.
Old Jan 16, 2005 | 07:14 PM
Anytime!
Old Jan 18, 2005 | 05:02 PM
kraut187's Avatar
So i got the codes turned off but discovered cylinder 1 was firing sporadically, so plugs and wires are on the way. Also found that an O2 sensor is going bad. When I got my other codes turned off they turned off the rear O2 sensors, is there any reason i can't move the o2 sim currently on the rear to the front dead sensor?
TIA
