New Pacesetter LTs
Old Jan 18, 2005 | 03:07 PM
DOUBT IT's Avatar
Default New Pacesetter LTs
I have some Pacesetter Race Long Tubes ordered from TSP, and due to arrive the end of this week or the beginning of next. ( Great Customer Service, by the way. ) I was just wondering about the installation tricks needed to get them in without a hitch. I've seen guides saying that you have to notch the K-member, or grind off the block tab, but I've also seen guides stating that you don't have to. Apparently it's all in the version of the headers, whether they're the new revision or not.
Can anyone give me a definative answer on this? I just don't want to have to do any more cutting/grinding than I have to. Also, please don't just point me towards an install guide. I think that I've read pretty much all of them.
Thanks in advance.
Old Jan 18, 2005 | 03:15 PM
SStillSSmokin's Avatar
Just put a set of the race headers on about a month ago. You do not need to notch or grind anything. Just get the car up as high as you can, and install from the bottom. Piece of cake! I had to pull the #7 spark plug to get my drivers side in, most say they didn't. It's a great time to put new plugs in anyway.
Good luck!!
Old Jan 18, 2005 | 03:16 PM
-Q-'s Avatar
-Q-
I had to grind off the tab on the block. Some people don't. You'll know real quick when you try to stick the driver's side header up there.
Old Jan 18, 2005 | 03:20 PM
Keenov's Avatar
Installed them on two camaros (98 and 00). Nothing needed to be modified, they went on perfect
Old Jan 18, 2005 | 03:29 PM
cyphur's Avatar
you should be getting the new revision pacesetters, and they should install quite easily. i installed a set of kooks the other day and it was a peice of cake.
Old Jan 18, 2005 | 05:11 PM
CWallen's Avatar
I just installed mine Friday and I didn't have to grind anything. They slid right in.
Old Jan 18, 2005 | 06:45 PM
LS1PoweredZ28's Avatar
I cut off the block tab with a saw, took about 5 minutes. Other than that they slid right in. As mentioned before, just get the car WAY up in the air.
Kevin
Old Jan 18, 2005 | 07:41 PM
4.6gt-2-ls1ta's Avatar
I put mine on Saturday race version coated and didn't remove any plugs or anything. they went in with out any trouble and I did it by myself on my garage floor on jack stands. EASY install, good luck and enjoy them.
Old Jan 18, 2005 | 08:32 PM
ss rally red's Avatar
Pacesetters = cake install, old or new style.....
Old Jan 18, 2005 | 08:38 PM
777's Avatar
777
^hmmm...i'd be leary of saying that...there were quite a few problems with the old style
Old Jan 18, 2005 | 09:25 PM
SupahRich's Avatar
How long did you guys wait for your coated Pacesetter's to arrive after placing the order? The order for mine went out last Monday... just curious how much longer I have to wait until I can check them out
Old Jan 18, 2005 | 09:35 PM
thebernsZ28's Avatar
I installed a set two weeks ago and it was not as bad as I thought it would be. I did not have to modify anything, everything just slid into place but there might be a snug fit under the driver where the header meets the Y-pipe, when I got on it after the install it hit the bottom of the car. If this will be a problem either beat the **** out of it to knock the bottom up, you can use radiator hose and clamps wedged in there, or order another hanger that was designed for that problem. Don't know the link for the hanger, Sorry.
Oh yeah, jack that **** UP UP UP UP UP.
Old Jan 18, 2005 | 09:36 PM
It took mine about a two and a half weeks but the LT's were on back order.
Old Jan 18, 2005 | 10:07 PM
luv2spd's Avatar
I have the old style and they were still easy to put in. It took like 2 minutes to notch the k-member a little with a grinder. I also cut the casting off of the block with a sawz-all.
Old Jan 19, 2005 | 01:03 AM
DOUBT IT's Avatar
Thanks for the replys everyone.
I guess we'll just see what happens when they come in. I'm gonna use my jack and some 4x4 pieces of wood to get the car up on some 6 ton stands, so height shouldn't be a problem.
Also, I'm gonna ride around for about two or three weeks on open headers :, while I wait on my tax return money, and then I'm gonna get the TSP True Duals, so there'll be no Y-pipe fitment problem...
Old Jan 19, 2005 | 11:20 AM
ritz's Avatar
I ordered my LT's from TSP on the 9th and my order still says "processing..." oh well. They do have great customer service because Jason let me know that they have to get the LT's from Pacesetter. Unlike F-body motorsports who I ordered a Spohn STB from 2 weeks ago and I'm just now getting the invoice in the mail, but still no STB.
Old Jan 19, 2005 | 11:28 AM
JackZ28's Avatar
I highly recommend removing the spark plugs prior to any exhaust manifold/header swap, unless you plan on replacing them at the same time. Also, put the new spark plugs (or the old ones for that matter) on after you put the headers on. If you don't you run the risk of snapping one or more of them. Even if you're extremely careful, it's wiser to just remove them.
Old Jan 19, 2005 | 12:11 PM
ritz's Avatar
I'm getting a local guy to install mine because I do not have access to a lift. I was a little weary of letting someone do this, but this guy has an amazing WRX and a Foxbody Vert 5.0with a crazy suspension set-up and Hoosiers all the way around that dominates the Auto-X. He recently installed Pacesetters on an 02 WS6 and was higly pleased and even went the extra mile and put a couple small pieces of header wrap on part of the LT's where the plug wires might touch.
Old Jan 19, 2005 | 12:35 PM
Open headers= LOUD!!! I finished my header install around 9:30 on a sunday night and fired her up, and DAMN it was loud I loved it, but the 3 neighbors that came out of their house wondering what just happened didn't.
Enjoy!
Old Jan 19, 2005 | 08:04 PM
DOUBT IT's Avatar
Neighbors =
Me =
They dealt with my truck ( hot 305 w/headers, no cat, and magnaflow ) and my Corvette Stingray ( 350 w/cam, no cat, cherry bombs ), so they can deal with my Camaro.
