Which Pulley?
Old Jan 19, 2005 | 01:53 PM
mc01ta's Avatar
Default Which Pulley?
I have an 01 Trans Am M6, looking for a pulley. Should I go with March, ASP, or SLP. I'm leaning towards the March. Also do i need both pulleys? I would rather skip the alt if that is ok.
Old Jan 19, 2005 | 02:02 PM
BriancWS6's Avatar
I've had zero issues with the march pulley since I installed it back in July. I didn't get the OD alt pulley and with a 10" sub I have no charging issues either.
Old Jan 19, 2005 | 02:10 PM
Time2Kill's Avatar
MASS seller approved
Either go with the ASP or March pulley. The ASP pulley is SFI certified and has been around for a couple of years with proven results.
You dont need the alt pulley, but you won't be getting the full gain of HP by skipping it. With the M6, you would not have any charging issues unless you have a HUGE system in your car that drains a lot of power.
We are also have a sale on the ASP pulleys right now
Old Jan 19, 2005 | 02:19 PM
code4's Avatar
I recommend ASP, & I didn't change the alt pulley. No issues with charging.
Old Jan 19, 2005 | 02:22 PM
mc01ta's Avatar
so I need both for full hp gains? I thought most were getting 8-10 by using the crank only, maybe I'm wrong. I don't have a huge stereo so charging isn't a biggie, i just want more power and know this is a proven mod
Old Jan 19, 2005 | 03:19 PM
tomaSS's Avatar
How would you not be getting the full HP gains by not installing the alternator overdrive pulley?
Old Jan 20, 2005 | 12:04 AM
Time2Kill's Avatar
ASP also sells an alternator UNDERdrive pulley. Makes it easier for the engine to turn the alternator therefore increasing horsepower. It's not recommended for A4s because they have a hard time reaching full charge at idle. The M6s idle higher and dont have a problem unless you have a big drain on your battery.
Old Jan 20, 2005 | 12:24 AM
matts22's Avatar
Will both the ASP and March work with Rollmaster Double Roller Timing Chains? That might be something to consider if you plan on it in the future.
 Michael S. Palmer
Old Jan 20, 2005 | 12:29 AM
01TAFlyer's Avatar
Would raising idle on an A4 fix that problem, like to 750rpm for example.
Old Jan 20, 2005 | 12:30 AM
LS1_PNYTAMR's Avatar
yes good question.. and waht about a cam a4 idling around 850-900rpms? would that be enuff..
damn pulleys are confusing lol
Old Jan 20, 2005 | 02:18 AM
LS1LT1's Avatar
Thumbs up
ASP Pulley
Old Jan 20, 2005 | 02:19 AM
Blacker's Avatar
I have mine idling at 800rpm and have a full charge. Without the FMS Cam, I was idling in gear at 650rpm and was fine.
Old Jan 20, 2005 | 02:49 PM
tomaSS's Avatar
How much more HP would you gain with the alternator UNDERdrive pulley?
Old Jan 20, 2005 | 05:24 PM
Time2Kill's Avatar
About 2 or 3hp. Definately worth it for $20
Old Jan 20, 2005 | 06:21 PM
matts22's Avatar
Unless you will have charging issues. Then, definately not worth it.
And I still would like to know if both ASP and March Pulleys work with the Rollmaster Double Roller timing chain and ported ls6 oil pump. From what I have read by searching, the newer ASP seems to work but March is up in the air. It has worked for some, but no sponsor or anyone has said it will work. Also, when you don't consider the fluid in the march as rotating mass, which weighs more? Which has deeper grooves so the belts won't slip? Do they both underdrive the same amount? These are the things I want to know.
Old Jan 20, 2005 | 06:28 PM
Scotty-Z's Avatar
Go for the ASP. Tried and proven for some time now.
Old Jan 20, 2005 | 07:36 PM
Mike98WS6's Avatar
I have the ASP no problems here.
Old Jan 20, 2005 | 08:25 PM
52172's Avatar
asp no problems here don't need the alt pulley even with two 600 watt jbl amps.
Old Jan 21, 2005 | 04:00 AM
ZR2877's Avatar
Glad I orderd the ASP pulley heard nothing but good things about them.
Old Jan 23, 2005 | 10:37 PM
texasuperman's Avatar
you made the right choice going with the asp
