Gauges and headlights flickering
Old Jan 20, 2005 | 11:33 PM
blu98ta's Avatar
Default Gauges and headlights flickering
My gauges and headlights are flickering. I mainly notice it when I turn the car on after cooling off for awhile. It seems pretty bad. Does anyone know what this could be? The battery gauge also bounces while it is doing this. It doesn't bounce a lot, but it is noticeable. WTF??
Old Jan 20, 2005 | 11:37 PM
PureWS6's Avatar
well all of the problems I've had with gauges in the past on my other non LS1 cars have been ground related........
Old Jan 21, 2005 | 02:08 AM
LSWannabe's Avatar
Thoroughly investigate the battery and it's connections.
Old Jan 21, 2005 | 12:21 PM
GT Griller's Avatar
Yea definatley check the batter cables. Samething happen to my friends TA a while back and it was the possitive wire was loose and was touching one of the pullies and had been burned thru.
Old Jan 22, 2005 | 02:15 PM
Time2Kill's Avatar
MASS seller approved
Definately check battery/grounds like the above posts say, but I 've also seen a similiar problem and it was because the #8 spark plug wire fell off and the coil pack was arcing to all the wires back behind the motor.
