ls6 intake install on a 99
Old Jan 25, 2005 | 03:14 PM
RedHardSupra's Avatar
Default ls6 intake install on a 99
I got the intake, but I know I need the coolant crossover pipe and two coolant plugs. Anything else?
Also, I'm thinking of doing the LS6 PCV conversion. Is it worth the effort if I already got a oil catch can?
What else should I do while I'm doing that? I know I will need EGR blockoff plates for the intake. Should I go with complete AIR/EGR removal, even if I still have stock headers? AIR pump is already removed physically and from the PCM.
thanks,
Marcin
Old Jan 25, 2005 | 03:19 PM
Keenov's Avatar
Make sure the gaskets are on there.
You will need the block off plate(s) for the exhaust manifold(s).
I would remove the EGR and leave the AIR connected if you still have cats.
Old Jan 25, 2005 | 05:04 PM
ArcticZ28's Avatar
I'm gonna be getting an LS6 intake as well for my 96... do you NEED the EGR blockoff plates? For instance, I'm buying an LS6 intake from TSP, therefore what else do I need to buy other than just the intake? Hopefully this can help RedHard as well.
Old Jan 26, 2005 | 03:24 PM
Keenov's Avatar
Well, you need to buy an LS1 longblock, if you haven't already, for that 96 you have.
Then you could buy a front coolant pipe from a 2001+ camaro/firebird and block off pieces for the back.
Sponsers sell them --> (ex. TSP)
Old Jan 26, 2005 | 03:40 PM
777's Avatar
777
i think he meant 99 but i could be wrong
Old Jan 26, 2005 | 04:04 PM
Redlinez's Avatar
Hint: due to the non availability of those rear bypass tubes, you can do what I did. I used a dremel and removed most of that criss crossed plastic on the bottom of the intake where the factory coolant lines run. I've had no problems with mine. Got that hint from Trevor himself. My headers had no egr provisions anyway.
Old Jan 26, 2005 | 04:09 PM
Keenov's Avatar
Probably.. but you never know.
*Now that I checked his profile, it is a 98+
