2 ton jackstand tall enough?
Old Jan 26, 2005 | 02:56 PM
john shea's Avatar
Default 2 ton jackstand tall enough?
Is a 2 ton jackstand tall enough for a header install?
john
Old Jan 26, 2005 | 03:16 PM
GuitsBoy's Avatar
I used them, with the back on rhino ramps.
Old Jan 26, 2005 | 03:45 PM
DOUBT IT's Avatar
I used three ton stands on 4" concrete blocks. I had to use a few pieces of wood on top of the jack. I measured 14" of clearance at the passenger side wheel, and I took the heat shield off. Then it slid right in.
Old Jan 26, 2005 | 08:16 PM
4.6gt-2-ls1ta's Avatar
i also had the rear tires on ramps and front on just jackstands. they slid right in like butter
Old Jan 26, 2005 | 09:00 PM
ddelallata's Avatar
I used 2 2-ton stands on top of some old disk brake rotors that I had laying around.
Old Jan 26, 2005 | 09:31 PM
Full-Force's Avatar
order you some 6 ton stands from Harbor Freight for 18 bucks for the pair and it will get the car up high enough for anything and be very stabe since they have a wider stance
