Meziere electric pump harness?
Old Jan 27, 2005 | 09:50 PM
SVC707's Avatar
Default Meziere electric pump harness?
Where can i get one. Bought the pump off someone on the board who said he would supply me with everything to install this and of course i cant install it without the harness... It says its a delphi piece. who knows where i can get this harness from
Thanks Steve
Old Jan 28, 2005 | 10:04 AM
Steve Burger's Avatar
LS1TECH Sponsor
Are you talking about the 2 wires off the pump? If so call one of the sponsors and they shouldbe able to help. If you are talking about the relay and associated wiring, go to www.ls1howto.com and look at their instructions.
Old Jan 28, 2005 | 12:59 PM
93LS1RX7's Avatar
It should just be a 2-wire hook it into a relay as shown in the link about and you are good to go.
Old Jan 28, 2005 | 08:06 PM
SVC707's Avatar
i know about the realy and such using my own wires, but i need the other end that will plug into the pump wire harness
Old Jan 28, 2005 | 08:20 PM
slow ride's Avatar
It does not plug into the harness. You have to find a wire that is hot when the key is on and splice or tap it on.
Old Jan 28, 2005 | 08:24 PM
SVC707's Avatar
as you can see there is a plug to the pump, then you hard wire to the car. as i said i am aware that i will use a relay but i need the other end to the actual pump.
Old Jan 28, 2005 | 09:08 PM
slow ride's Avatar
Order it from Meziere they are in Ca.
