Installed Poly Engine Mounts
Old Jan 30, 2005 | 11:15 PM
Cstick's Avatar
Default Installed Poly Engine Mounts
Finally got the poly motor mounts installed. Man they are great, but they suck putting it. I have Pace Setter LT. I had to take both brackets off the frame to get the motor mount shell out. I thought about taking the headers off, but my ORY fits so tight I did not think I could get it apart or back together. The driver side was the worst. I honestly at one point wished I had not even started it, but it sure helped. No more Y pipe banging, the engine does not even rock or roll when you flick the throttle. The passenger side was so much easier. The A/C compressor will sit on the sway bar and you have much more room than the other side. When attempting this install schedule breaks because you will get frustrated, and tired if you are on a creeper doing this.
Old Jan 31, 2005 | 09:34 AM
Hardtop00SS's Avatar
do you have any false knock problems with the poly mounts? I've heard this was a problem with them...
Old Jan 31, 2005 | 10:41 AM
1999T/A's Avatar
I thought the false knocks were with solid motor mounts , not with polys . I haven't had a problem with my polys .
Old Jan 31, 2005 | 04:37 PM
hourang's Avatar
ive not heard of false knock with them either, i would think it would be the opposite, we were getting false knock before the poly mount due to headers hitting kmember.
it was a pita install, it does help to have a 15mm gear wrench for the bolts or youll be there all day. also the rivets in the mount took us forever with a die grinder, save your time and just drill the rivets out. otherwise a very good install to do if you have a cam.
Old Jan 31, 2005 | 04:40 PM
ok well I guess I was wrong I will have to look into these bad boys, where'd you get the them from?
Old Jan 31, 2005 | 04:47 PM
Cstick's Avatar
Only place I saw them was Thunder Racing, and I don't have a scanner to see if I am getting any knock, but I doubt it.
Old Jan 31, 2005 | 04:52 PM
Tranzor's Avatar
I have them too... really shored up the engine motion and made it so the exhaust didn't rattle around all the time.
The one unfortunate side effect is that the vibrations from the engine will be absorbed more into the frame... so I have more squeaks and rattles now in the cabin than I did before the swap.
Old Jan 31, 2005 | 05:26 PM
CamTom12's Avatar
even with the SFC's?
I've had a set for a couple of months that I've been trying to find the time to install... maybe I'll get some Kenny double-D's first, hahaha
 Michael S. Palmer
Old Jan 31, 2005 | 05:35 PM
Tranzor's Avatar
Yep even with them... of course, my car is just a symphony of odd sounds as I cruise down the road. I have poly bushings and mounts everywhere possible, so I have lots of rattles in the center console, the seats, the dash, etc, I have a Pro 5.0 shifter that has no rubber insulation like the stocker so along with my poly trans mount I can hear just about everything going on in the transmission, I have a Moser with 4.11 gears that whine like a banshee, a rumbler catback coupled with my cam so the exhaust is pretty damn loud...
But hey, at least I have ZERO wheel hop and my car will liquify my street tires if I push the pedal to the floor at any time in first or second gear... and will light 'em up when I downshift from 4th to 3rd.
Old Feb 1, 2005 | 01:39 PM
hourang's Avatar
yeah the increased noises is normal with poly bushings. almost makes you want to use rubber, almost
Old Feb 1, 2005 | 02:17 PM
Blue Falcon's Avatar
my poly's had to be cut down to fit in the clamshell, that was the only problem I had.
Old Feb 2, 2005 | 11:30 AM
hourang's Avatar
hrm, maybe you didnt get all the old material out. we had to clean it real good and even then we had to hammer the mount place, then it fit. also another note, trying to line the new engine mount with the chassis mount was a lil difficult, finally got it in by using a crowbar to pull the motor away.
Old Feb 2, 2005 | 11:37 AM
I had the motor out of the car but I've got to fix the mount because the welds my engine shop put on it broke..
There was no material, it just kept hitting the metal part of the clamshell. I questioned one of the guys at Speed Inc. several times to make sure they were sending me the correct ones.
Old Feb 2, 2005 | 11:43 AM
hourang's Avatar
just curious but what was the reason for welding the mounts? also i dont understand what you are talking about without seeing it or more explanation, the whole clamshell is metal and the poly urathane is contoured to fit the shape of the metal. we couldnt get ours to fit in there without persuation, it was a tight fit and the urathane dont slide on metal very well.
Old Feb 2, 2005 | 06:25 PM
Full-Force's Avatar
I have prothane poly mounts and they fit right. Now you wont be able to put the clamshells back together until they meet up by hand because then they would be a solid mount. You will have to pull them together with the new bolts. I put grease on mine before I put them in the clamshells and then tightened them with my small impact gun.
Old Feb 2, 2005 | 09:23 PM
Red99TA's Avatar
I just did my driver's side last week and I agree...it totally sucked. It took me a good 6 or 7 hours for that but 99% less y-pipe banging now (just the occasional tap starting from a stop). I'll sell my leftover passenger mount (identical to the driver's side) if anybody wants it...there's no way in hell I'm going through that crap again just for the passenger side.
Old Feb 3, 2005 | 07:50 AM
NateLS1's Avatar
Boil the Polyurethane Mounts and put them in before they cool off. they become soft, well softer anyways.
Old Feb 4, 2005 | 07:08 PM
mrbobo's Avatar
I just installed the Poly mounts on my car, and it was somewhat a PITA .... but I was installing headers anyways so I figured "now is the time". I won't know until about mid April, how the mounts are - when I put the car back on the road (I don't drive it in the winter/salt). Oh, and... GearWrenches Rock!
Old Feb 6, 2005 | 09:41 AM
shep28's Avatar
I have a set ready for install, but after looking at my headers, I don't see how you can fit a wrench in there to take off the upper engine mount bolts. I wish I had done this when my headers were off.
Old Feb 6, 2005 | 09:43 PM
Cstick's Avatar
Oh it is possible! I have the same headers, but if you can get your exhaust apart it will probably save you some time from getting the top eninge mount bolts in and out.
