Iron block and poly motormounts????
When I had my LT1 Z28 I had a poly trans mount and it tightened up the tranny very well and didn't cause any vibration, when I first got my 98 Z28 I installed A poly trans mount but in this car the vibration was unbearable, after a quick drive down the street I pulled it out and installed the stocker.
I know that aluminum doesn't absorb as much vibration as iron and was more than likely the reason for the mount not working well in this car.
I also read here that some people run a poly mount on the drivers side and keep the stock mount on the pass. side.
I just don't want to have any obnoxious vibrations in the car since it is my daily driver and I do take it on long trips.
Thanks.
) with poly mounts. Only time I notice them is setting at a light, I get a little bumping from the cam.
