Oil Question
Old Feb 14, 2005 | 08:30 PM
ZeeQuick's Avatar
Default Oil Question
Somebody told me that I might want to consider switching to Mobil One Synthetic 15W-50 in the summer time. They think that it will better protect my engine with the warmer temps and all. I have run the 10W-30 Mobil One Synthetic year round in the car since I bought it with 39K miles....it now has a little over 94K on the clock. Should I just stick with the 10W-30??
Old Feb 17, 2005 | 04:22 PM
WILWAXU's Avatar
I normally run 10/30 Mobil 1
Old Feb 17, 2005 | 09:16 PM
Gloveperson's Avatar
Same here...I don't think going to 15 will help anything at all.
Old Feb 17, 2005 | 10:11 PM
Ron78Z&01SS's Avatar
The owner's manual (for 2001 at least) says to use 5W30 OR 10W30. It SPECIFICALLY cautions about using any other grade.
Old Feb 17, 2005 | 11:17 PM
TheBlurLS1's Avatar
That's what she said...
there's also a restrictor in the clutch hydro line, but everone drills THAT bitch out
PM patman and ask him, he's our local oil guru, he'll getcha setup
Old Feb 17, 2005 | 11:35 PM
KrazyDan's Avatar
If you look around, you are going to see if you go with mobil 1, they will recommend 0-40.
From all the oil threads here lately, you will see german castrol 0-30 is the "hot" topic.
