intsalling loud mouth
Old Feb 15, 2005 | 11:20 PM
anthonyz281999's Avatar
Default intsalling loud mouth
i just bought the SLP loud mouth with the center mount quad tip i was just wonderin if that would be to hard to install myself or something i could do fairly easily if the cars on jack stands ???
Old Feb 16, 2005 | 06:18 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
It's not really hard installing it. But if you have the stock exhaust , a sawzall will be your friend. If you want to remove the stock exhaust intact, you'll have to remove the pass side tire, coil, etc to slide it out, I believe.
If you even THINK you'll ever want to remove the LM intact, I would suggest using a liberal amount of anti-seize on the section that goes over the axle.
Old Feb 16, 2005 | 09:14 AM
HAUS1's Avatar
Nahhh man, if you have a saw, your good to go. It is very easy!
Old Feb 16, 2005 | 12:17 PM
FatZ28's Avatar
A sawzall is your bestfriend when it comes to exhaust.....
